Put the car to TDC and pull off the front covers and check the belt to see if the gears are all lined up. The time you have spent to diag. you could have taken off the top two timing covers, four compressor pipes and like 10 allen head bolts to check the cover and see. You don't have an upper fan shroud which helps save time.
